12/3/2008 10:18 AM | |
Joined: 11/9/2008 Last visit: 8/23/2024 Posts: 410 Rating: (6) |
Dear All, 1) I'm using Wincc 6.2 SP2 i want to generate reports for last 1 month and tag logging time is every 1 min and 1 Hour. Can you guide me about tag logging setting because i'm not familler with this.I'm sending PPT for your referance which setting need to set. 2) I'm also facing one problem whenI put wincc in runtime thenrun timestuck at "Taglogging Run time" and project not start in runtime. Then i have to delete all log tags. After deleting this log tag wincc runtime work fine. Please suggest what is the problem and what setting to be need? Regards, YogendraG Attachmenttag logging setting.ppt _Compatibility Mode_.pdf (242 Downloads) |
