4/24/2012 1:45 PM | |
Posts: 54 Rating:
Hello, thank you for helps, I am try says. same error contunie.. |
4/25/2012 11:16 AM | |
Posts: 3037 Rating:
Hello, You can contact the customer support with the behaviour of your project. ---> customer support Tweety |
5/9/2012 2:08 PM | |
Posts: 54 Rating:
Upgrade wincc pro. v11 sp2, problem was solved |
5/18/2012 11:55 AM | |
Posts: 54 Rating:
hello, if your problem not solved.reinstall sql server then install sql server try again |
