10/6/2005 4:24 PM | |
Joined: 9/27/2005 Last visit: 11/27/2007 Posts: 1398 Rating:
There are blocks available for the S7-300 and 400 that will transfer the data up to WinCC. This faq makes a good starting point http://support.automation.siemens.com/WW/view/en/21738814 Hope this helps, Salma |
10/10/2005 5:41 PM | |
Posts: 3149 Rating:
Hello Feffe, perhaps will the following PCS7-FAQ/Manual answer some of your questions, if you are using PCS7 and need a 10 ms time stamp....: http://support.automation.siemens.com/WW/view/de/15389927 http://support.automation.siemens.com/WW/view/de/15231179 Best regards, Nemo |
