1/17/2024 2:29 PM | |
Joined: 11/30/2006 Last visit: 7/4/2024 Posts: 59 Rating:
Hello Calt, I have exactly the same problem with WinCC v7.5. I can not browse OPCServer.WinCC.... Did you find the solution? BR, Djordje
Last edited by: The Helping Hand at: 01/18/2024 09:49:02New subject after splitting |
2/2/2024 9:55 AM | |
Joined: 8/3/2009 Last visit: 9/6/2024 Posts: 13580 Rating:
Hello Djordje Check out this FAQ: https://support.industry.siemens.com/cs/de/en/view/109763316 If you have problems with browsing it could also be good to refresh the temporary data: https://support.industry.siemens.com/cs/de/en/view/109763043 Bye Murof |
2/5/2024 2:22 PM | |
I tried already all .... Moderator splited my post to new one. It apears that the problem is with project after migration....
2/7/2024 7:11 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating:
Closed cause question posted twice. The second thread with the subject After migrating PCS7 project from 7.0 to 9.1 OPC Server WinCC is running but it has browse error. is published within the conference Process Control Systems SIMATIC PCS 7. Jen_Moderator |
