4/5/2023 9:24 AM | |
Joined: 8/3/2009 Last visit: 7/11/2024 Posts: 13284 Rating: (1685)
Hello nfgfhjhju If you do not have advaced scripting abilities you can slso use PM Open Eport. This should do the same as you would need for your usecase. Or you write your csv file by VB Script: https://support.industry.siemens.com/cs/de/en/view/850338 Bye Murof |
