5/2/2012 11:14 PM | |
Joined: 5/27/2009 Last visit: 8/14/2024 Posts: 122 Rating:
Hi, i'm using 64 bits Windows Server 2008 R2, but during installation there was not errors. |
5/3/2012 4:28 AM | |
Joined: 3/18/2008 Last visit: 12/8/2023 Posts: 1750 Rating:
Hello Zein, i hope now you have got an answer for your problem. you will have to install 32-bit OS in this case as mentioned by Ammy in earlier reply. Please find the attched file for your reference. AttachmentWinCC V7.0 SP3.pdf (452 Downloads) |
5/3/2012 8:34 AM | |
Joined: 4/19/2008 Last visit: 6/25/2024 Posts: 1525 Rating:
Hello Amit_86 Server 2008 R2 is Supported by the WinCC V7.0 SP3 Have a look on the following FAQ for More Detail. With what are SIMATIC WinCC V7.x, V 6.x and V5.x compatible? |
Ammy |
2 thankful Users |
5/5/2012 12:10 AM | |
Hello Zein, Currently I am working with WinCC V7.0 SP3 on Windows Server 2008 R2 & its working without any problem, also Winows 7 Ultimate, are you getting same problem on Windows 7 Machine ? then You need to contact Support Request they will give you more detail. |
Ammy |
5/5/2012 7:07 PM | |
Posts: 947 Rating:
Hello for wincc 7.0 sp3 Update1 Released for Delivery http://support.automation.siemens.com/WW/view/en/59902881 may be it help you? |
5/7/2012 11:27 AM | |
Joined: 5/7/2012 Last visit: 8/8/2024 Posts: 1 Rating:
Check this maybe help /tf/WW/en/Posts/69519#top |
