11/23/2023 7:19 AM | |
Joined: 8/3/2009 Last visit: 5/8/2024 Posts: 12909 Rating: (1645)
Hello kociński_adrian172 You should do the reading and writing of WinCC Tags in a different syntax like this: https://support.industry.siemens.com/cs/ww/en/view/109818193/118089674379 there is also an example of accessing Excel: https://support.industry.siemens.com/cs/ww/en/view/109818193 -> Chapter 3.6.16.3 Bye Murof |
