9/25/2008 3:16 PM | |
Posts: 196 Rating: (12) |
You can setup the log function under alarm “management/settings / alarm groups” Here can you activate the log function. Then setup the log function under “Historical data” After that you can insert the alarm window and chose the log function Here is linker where you can read more about the alarm function in winCC flex. |
