11/27/2018 12:19 PM | |
Joined: 8/3/2009 Last visit: 7/11/2024 Posts: 13284 Rating:
Hello I would use for testing the Siemens SmartClient Application: https://support.industry.siemens.com/cs/de/en/view/109482434 And first check on the HMI RT PC the client localy (its already installed!) that you r Smart Server runs. Then you can check from remote PC. Bye Murof |
