11/18/2022 2:09 PM | |
Joined: 7/19/2022 Last visit: 5/9/2024 Posts: 358 Rating: (61) |
Hi jjsipazopp, The working memory of your CPU depends on the exact model you have. For example IM151-8F PN/DP CPUs have 256KB of working memory (6ES7151-8FB01-0AB0) and older ones have 192KB (6ES7151-8FB00-0AB0). Another thing to keep in mind is that not all block memory goes into working memory. There are parts that go to the load memory, others to the retentive memory... Therefore, when you go online you will see that you have a lower amount of working memory than what you got by adding up what each block occupies.
