5/21/2024 9:16 AM | |
Joined: 4/28/2015 Last visit: 7/31/2024 Posts: 20 Rating:
Latest News to this Topic! Feedback from Techncial Support Germany to my colleague: "The issue is still under investigation". Affected TIA Portal-Versions:
Affected Microsoft-Updates:
Quick workaround: uninstall the KB or use a virtual machine without the above updates. Best Regards 2024-05-27 > Update: there is a new FAQ with further workarounds: 2024-06-05 > Update: you can get an patch from SIEMENS by opening a support request (SR) at the technical support. Also mentioned in the section "Solution" of the FAQ 109971630. |
Last edited by: LC7032 at: 05/27/2024 13:35:26Last edited by: LC7032 at: 05/27/2024 13:36:30Last edited by: Jen_Moderator at: 05/28/2024 04:24:00Copy of post created. Last edited by: LC7032 at: 06/05/2024 12:56:59Last edited by: Jen_Moderator at: 06/06/2024 05:24:43Headline optimized. |
5/25/2024 5:33 PM | |
Joined: 4/28/2015 Last visit: 5/30/2024 Posts: 11 Rating:
See also https://support.industry.siemens.com/cs/us/en/view/109971630 |
Last edited by: AutoGen_861515 at: 05/25/2024 17:33:54Last edited by: Jen_Moderator at: 05/27/2024 05:19:36Link optimized. Last edited by: Jen_Moderator at: 05/28/2024 04:24:13Copy of post created |
6/5/2024 12:52 PM | |
Hey Guys, as of today, there is a patch for TIA from SIEMENS. You can get it with a ticket (SR) to Technical Support. This is what it says in the "Solution" section of the FAQ with the ID: 109971630 |
4 thankful Users |
