9/20/2023 6:22 PM | |
Joined: 9/13/2023 Last visit: 11/6/2023 Posts: 7 Rating: (0) |
hallo ich want to initiate ein siprotec4 device. was should i tun? pardon me for combining GER & ENG ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/21/2023 09:10:01New subject after splitting |
9/20/2023 8:03 PM | |
Joined: 9/27/2006 Last visit: 5/21/2024 Posts: 12257 Rating: (2668) |
Hello; May I suggest you start with a bit of reading? The system manual for Siprotec 4 relays is available in the followig link, it provides a lot of good information on that family of protection relays. The manual is available in German also, if that makes your life easier, open the link Langages and Countries in the links below,, available versions of the manual are shown at the top of the page..
https://support.industry.siemens.com/cs/ca/en/view/109742467 You will need to install the DIGSI 4 software in order to configure and operate the Siprotec relays. It is a licensed software, but Siemens offers a Trial download for DIGSI 4, fully functional for 30 days; once the trial license expires, you are expected to purchase the full license from your nearest Siemens distributor.
https://support.industry.siemens.com/cs/ca/en/view/109740982 Each relay model is used to protect different parts of the power grid and has its own spcific design. You will need to download the manual for the relay you wnat to control (use the search box at the top of this page, with the part number of the relay as a search term) for more informgion, and you will need to look up th device driver for the communication link you want to install on this relay (they are available on the download link above). The Siprotec 4 catalog is also a source of a great deal of detailed information:
https://support.industry.siemens.com/cs/ca/en/view/109802608 Finally, Siprotec 4 tutorials from Siemens are available here: https://www.siemens.com/global/en/products/energy/energy-automation-and-smart-grid/webinars.html Hope this helps, Daniel Chartier |
