6/29/2018 4:13 PM | |
Joined: 10/7/2016 Last visit: 5/22/2024 Posts: 66 Rating:
Hi, I need to write names in some Tag on WinCC Runtime. How can I do it? |
6/30/2018 8:54 PM | |
Joined: 9/19/2009 Last visit: 5/11/2024 Posts: 458 Rating:
Hi You can try this code: Static Text : Object Name : TxtName Button : Object Name : BtnReadTag Tag : "Name" Event Button:
However you can do it automatic when you tag change if you use the properties of static text and text propertie. Regards |
If my answer help you, use the Thanks or Rate Button, It is free of charge :-) |
