2/5/2020 10:39 AM | |
Joined: 8/3/2009 Last visit: 8/6/2024 Posts: 13451 Rating:
Hello Ahmed of course you can also write your own procedure with a VB Script. you can use HMI Tags and write them in a CSV File and with another Script you can read out the Script again and write it back to the HMI Tags: Comfort Panel https://support.industry.siemens.com/cs/ww/en/view/59604194 RT Advanced
Bye Murof |
