9/7/2020 2:04 PM | |
Posts: 9 Rating:
Hi,
I prepare script which was testing by simulation. It is working and writing data on hard drive to PC . When I modify script for TP700 and after download the problem start. Via breakpoint i see that script is correctly working in TP700 but nothing is writing on USB or SD cards.All what i try is -> 1. Use USB and SD, format with FAT32 on 2GB allocation unit size 2. PC path was defined like : Cesta ="C:\archiv\" - it was writting USB path was defined like : Cesta ="\Storage Card USB\" - not writting SD path was defined like : Cesta ="\Storage Card SD\" - not writting
I prepare some examples of define path Cesta = "\Storage Card USB"NazovSuboru = "GDI_" & SmartTags("DMC") & ".csv" If SmartTags("#OP302_HMI.Production.Reset_Req_Production") Then NazovSuboru = "GDI_" & SmartTags("DMC") & ".csv" End If Cesta = "\Storage Card USB\" NazovSuboru = "GDI_" & SmartTags("DMC") & ".csv" If SmartTags("#OP302_HMI.Production.Reset_Req_Production") Then NazovSuboru = "GDI_" & SmartTags("DMC") & ".csv" End If Can you help me? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/08/2020 08:48:21New subject after splitting |
9/8/2020 8:50 AM | |
Joined: 6/19/2017 Last visit: 8/5/2024 Posts: 8175 Rating:
Best regards, Jen_Moderator |
