7/19/2017 1:18 PM | |
Joined: 10/5/2016 Last visit: 9/12/2022 Posts: 236 Rating: (7) |
"The representation of tags in the form of functions over time is only possible, if the values of the trend are supplied through the API interface." So I can't use WinCC tags directly? What way to do it? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/21/2017 11:56:23 AMNew subject after splitting Last edited by: KCD at: 7/27/2017 3:25:17 PM |
7/27/2017 3:25 PM | |
Solved by inserting array to the trend control. |
10/17/2017 11:57 AM | |
Joined: 3/3/2009 Last visit: 7/24/2024 Posts: 1 Rating: (0) |
Hi KCD! Can you give an example? Regards |
10/28/2020 2:20 PM | |
Joined: 11/8/2019 Last visit: 5/1/2023 Posts: 8 Rating: (0) |
Hello, could you kindly share your solution with array? Thanks |
