8/10/2022 2:51 PM | |
Joined: 8/8/2022 Last visit: 8/15/2022 Posts: 1 Rating: (0) |
Hi, i get this dialog and the user on the computer does not have the privileges on the computer to confirm the dialog. when i press OK i get the message: you do not have the sufficient rights to change the settings. communication works fine anyway, so i dont really need to change any settings here. But its annoying that the dialog pops up everytime the computer is restarted. what do i do? /Heja ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/11/2022 09:02:24New subject after splitting |
8/11/2022 9:12 AM | |
Joined: 5/30/2022 Last visit: 4/25/2024 Posts: 520 Rating: (85) |
Hi Hesha, I think your problem is in SIMATIC Shell, I recommend you to check this FAQ: https://support.industry.siemens.com/cs/de/en/view/25437381 You have to select a valid Ethernet Adapter and confirm the dialog and the dialog should not popup at OS Start again. |
If this information really helps, you could use the Rate function. |
