3/21/2024 7:32 AM | |
Joined: 6/15/2022 Last visit: 4/25/2024 Posts: 20 Rating: (0) |
Hi everyone, I enter the following parameters to do master slave axis coupling in Sinumerik, but the axes are not coupled. 37256 $MA_MS_TORQUE_CTRL_P_GAIN[AX8] = 0.5 37258 $MA_MS_TORQUE_CTRL_I_TIME[AX8] = 5 37264 $MA_MS_TENSION_TORQUE[AX8] = 15 37262 $MA_MS_COUPLING_ALWAYS_ACTIVE[AX2] = 1 37262 $MA_MS_COUPLING_ALWAYS_ACTIVE[AX8] = 1 AX2 Master(Y1) AX8 Slave(Y2) ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/22/2024 06:42:15New subject after splitting |
3/27/2024 3:28 AM | |
Joined: 10/17/2007 Last visit: 4/27/2024 Posts: 3974 Rating: (340)
If you are sure you have that option purchased. I suggest you to read Siemens manual very carefully you did not provide CNC type--for 840D I post FB3-manual cover --please read section 12 I hightailed remind--the Master axis is speed control and Slave axis should be current control (or call TORQUE control)
If you like my comments please |
3/27/2024 12:38 PM | |
Joined: 8/1/2013 Last visit: 4/9/2024 Posts: 120 Rating: (8) |
Hi: N37250 $MA_MS_ASSIGN_MASTER_SPEED_CMD[AX8]=2? ; 2 = AX2 You need to set for witch axis is assing the slave. Regards¡ |
