3/28/2022 1:04 PM | |
Joined: 11/24/2021 Last visit: 7/21/2023 Posts: 37 Rating:
Hello Please what is the probleme in this script ?? |
3/29/2022 10:20 AM | |
Joined: 6/14/2013 Last visit: 3/18/2023 Posts: 218 Rating:
Hi ESCANOOR, |
3/29/2022 12:37 PM | |
hi mirip sorry i tryed but it's not the solution of the probleme .. it's stiil the same message in the error window |
3/29/2022 2:25 PM | |
Joined: 9/3/2008 Last visit: 8/2/2024 Posts: 927 Rating:
Hi ESCANOOR The correct spelling is "ADODB.Connection" Also, remove the line: Set rst=connextion I hope this helps ;-) Regards |
Michael |
3/29/2022 5:27 PM | |
hi michel sorry it's not usefull .. itryed but it still the same errors thank you |
3/30/2022 1:22 PM | |
Joined: 8/3/2009 Last visit: 8/2/2024 Posts: 13440 Rating:
Hello ESCANOOR please have a look at the official application example: https://support.industry.siemens.com/cs/ww/en/view/26283062 Bye Murof |
3/30/2022 1:46 PM | |
hello Murof thank you for the link is full of information but it still the same .. i don't know what's syntax error is best regard |
4/6/2022 1:50 PM | |
Hello Of course it is full of information You can also use an internal Tag which you set to a specific value after every relevant script line. then you know exactly where the error is if you do not want to work with OnError...resume...next... Bye Murof |
Last edited by: Murof at: 04/06/2022 13:51:16If this Information really helps, you could use the Rate function |
