1/9/2018 2:38 PM | |
Posts: 5 Rating: (0) |
Hello, I would like to refresh that topic a little bit. We have two Field PGs in our company. One is a newer M4 and one an old M2 with WinXP, 2GB RAM and 60GB hard drive. We would like to upgrade that old one so we would be able to use it with new software TIA. My plan is to install 2x4GB DDR2 RAM and new hard drive. And here is my quetion. Is it possible to put into that PG SSD hdd? I know that there is SATA interface but it is SATA "I" where all of new SSDs has "III". Does anyone done it with success? Has some experience to share? Advice a drive that is working. Socondly I am planning to install 64bit OS. I thought about Win7Pro but I will need to use virtual machine with XP for old software. Thank you in advance Artur ------------------------------------------------------------------------------------------ |
Last edited by: Artur_P at: 1/9/2018 2:40:29 PMLast edited by: Jen_Moderator at: 1/15/2018 10:10:40 AMNew subject after splitting |
1/10/2018 7:14 AM | |
Thank you very much for a comprehensive answer. Appreciate it. It is very helpful! |
1/11/2018 9:01 AM | |
Posts: 8946 Rating: (999) |
You are welcome! |
1/11/2018 11:07 AM | |
Posts: 531 Rating: (34) |
Keep in mind that 8 GB ram and the old cpu might not be the best performance for an engineering person. For trouble shouting might work. |
1/12/2018 3:02 PM | |
Dear IBN, I believe that you installed Windows 7. Did you? I found information that there are drivers for Windows Vista but what about Win 7? Did you use win XP and Vista drivers and it worked? Or did you get Windows 7 drivers? Does Siemens support can help with that? Thank you in advance for your answer. wolves and hawksIt will be used by maintanence service as a second PG for troubleshooting only :) |
Last edited by: Artur_P at: 1/12/2018 3:04:54 PMLast edited by: Artur_P at: 1/12/2018 3:05:12 PM |
