Industry Online Support
3/28/2006 12:06 PM | |
Joined: 9/23/2005 Last visit: 6/4/2024 Posts: 4339 Rating: (1429) |
Hi, you can work in Profibus DP. CP 5613/ 5611 can be a DP master and the CP 541 can be a DP slave. In this way you can exchange just some words (I'm not sure but I think 32). In function of the number of the CPU's maybe you should use more thatone CP5613. the FAQhttp://support.automation.siemens.com/WW/view/en/17090003and http://support.automation.siemens.com/WW/view/en/1348028 give a idea how to do it. Just change a S7 PLC for a PC Station with CP5613 and OPC, for example. |
Denilson Pegaia |
3/28/2006 12:32 PM | ||||||||||||||||||||||||||||||||||||||||
Posts: 3149 Rating: (171) |
Hi, there is an Addon WinCC S5-Channel available (WinCC Competence Center in Erlangen): http://www.industry.siemens.com/IT4Industry/EN/SOLUTION_SERVICES/SIMATIC_ADDONS/kanal.htm
