3/7/2024 1:31 PM | |
Joined: 8/23/2022 Last visit: 6/11/2024 Posts: 10 Rating: (0) |
Greetings, We have a batching system for cement mixers that uses LIEBHERR as you can see it HERE for upgrading the control and batching system with to SIEMENS, what are the available alternatives for batching system in WinCC. I am thinking of something like an add-on not a manually programmed recipes. Regards |
3/7/2024 3:41 PM | |
Joined: 7/19/2022 Last visit: 6/21/2024 Posts: 370 Rating: (61) |
Hello AutoGen_5222403, For the application you are looking for, a DCS system like PCS 7 is what you need: SIMATIC PCS 7 – the distributed control system with proven performance PCS 7 is focused on distributed and process control systems and already integrates modules/libraries for this type of application. I would advise you to contact a Siemens distributor. |
3/10/2024 9:22 AM | |
ThanksK_Ohjus your reply was really helpful. [snip] |
Last edited by: Jen_Moderator at: 03/18/2024 09:47:55Division of question into separate topic. |
