5/7/2024 11:00 AM | |
Joined: 5/6/2022 Last visit: 7/31/2024 Posts: 437 Rating:
Hi karmalai, It's really strange behavior. The first thing I would recommend in this case is that you update to the latest version available, both in the engineering and runtime parts, to see if this improves the behavior. I leave you the download links for the updates below: Best regards!
5/8/2024 2:22 PM | |
Joined: 8/3/2009 Last visit: 7/31/2024 Posts: 13425 Rating:
Hello karmalai you can try to reset the runtime files with : https://support.industry.siemens.com/cs/de/en/view/109778709 do you have a different Windows Version on the two systems? Bye Murof |
