工业业务领域支持中心
11/15/2005 5:14 PM | |
Posts: 1 Rating:
I have MP370 and WinCC flex. Can I create a text file on flash memory and write values or strings to it, and read them back?? |
11/16/2005 9:09 AM | |
Posts: 38 Rating:
Hi. Have a look at this link http://msdn.microsoft.com/library/default.asp?url=/library/en-us/script56/html/sgprogrammingfilesystemobject.asp. It explains the filesystemobject, that you can use i the scripting tool i both protool and wincc flex. The pathname to your flashcard could be "\Storage Card2\filename" depending on in which slot you're using on the MP370. If not my memory fails me, the "Storage Card2" is for the compact flash slot and "Storage Card" is for the pcmcia slot. /Hope this helps |
