9/18/2018 4:30 PM | |
Joined: 10/18/2012 Last visit: 8/21/2024 Posts: 225 Rating: (23) |
Hello sam2014, to find out how much memory is used in RAM and how much is swapped in a Microsoft operating system, you can use the tool perfmon. For an example use of perfmon see https://serverfault.com/questions/399855/how-much-swap-is-being-used-on-windows, or try to search the web with your favourite search engine for "taskmanager ram swap". If you find out, that your system does a lot of swapping, then upgrading your available RAM might solve your performance problem. BR, |
