7/23/2022 4:14 PM | |
Joined: 9/27/2006 Last visit: 7/20/2024 Posts: 12270 Rating: (2676) |
Hello Loki; Qwazee's suggestion for the S7-200 Smart system manual is excellent, this is the best solution for your research: Section 7.2 onwards will describe the use of the PTO insructions, the SM bits required to control a pulse train output that you can use to establish a motion profile on a stepper motor. If you require further support on the S7-200 Smart PLC, you should consult Siemens India, users in Europe/America do not have much access to Smart documentation: https://new.siemens.com/in/en/products/automation/systems/industrial/plc/simatic-s7-200-smart.html Hope this helps, Daniel Chartier |
