2/20/2024 2:40 PM | |
Joined: 5/6/2022 Last visit: 10/18/2024 Posts: 470 Rating: (94) |
Hi modjla, Are you communicating the PLC with any WinCC Unified? I tell you this because this message usually occurs when this communication is made. Check out this FAQ that I share below that shows the same message in the diagnostic buffer as you: If it is not helpful, can you explain your architecture and if you communicate the PLC with other equipment? Best regards! |
