3/24/2017 3:42 PM | |
Posts: 69 Rating:
hello dchartier, i have the error Please find attached the image of the errori don't know how can i resolve it . thank you in advance for your helpy |
3/24/2017 3:58 PM | |
Joined: 9/27/2006 Last visit: 8/22/2024 Posts: 12279 Rating:
Hello norimane; Have a look at the attached screencaptures, from these manauls: SIMATIC S7-300 Instruction list S7-300 CPUs and ET 200 CPUs SIMATIC STEP 7 V5.5 Statement List (STL) for S7-300 and S7-400 Programming The AW instruction in STL is supported by your CPU, as you can see. It will apply a Word-wide AND between 2 values. Just wondering, how have you setup your LB value? If it has not been initiated in your function, you cannot know what it contains. What should you watch out for when using the local variable types OUT and TEMP in subprograms? Hope this helps |
3/24/2017 4:24 PM | |
Posts: 69 Rating:
hello dchartier, thank you very very very much. best regards |
