10/29/2020 6:08 PM | |
Joined: 10/26/2011 Last visit: 10/28/2024 Posts: 762 Rating: (191)
Hello nicosub These are rather few details for your task or what you want to do at all. Which PCS 7 version do you use? If you use a valid pcs 7 license, you do not need any other licenses for the ET 200SP. What information would you like to have? You have to specify it. Nobody knows what this test system looks like and what you want to engineer.
10/30/2020 10:31 AM | |
For beginners, siemens provides some documents to get to know the system, its philosophy and the numerous tools. This document describes in a step by step guide how to set up a small project from the beginning. Here you will learn all necessary steps and tools to engineer a pcs 7 project. SIMATIC Process Control System PCS 7 Getting Started - Part 1 (V9.0 with APL) Use the PDF document (pdf Download). The example project you will find in the appendix. If you have done this, you can do the part 2, to deepend your knowledge: SIMATIC Process Control System PCS 7 Getting Started - Part 2 (V9.0 with APL) The PCS 7 overview page provides all the information about PCS 7: manuals, application examples, FAQs, movies, apps, etc. Have also a look to the compendium parts: |
11/2/2020 1:14 PM | |
The "SIMATIC Simulation Platform" software is used for simulation in the process automation and pcs 7 environment. You can get a good overview of the software on the corresponding topic view. SIMATIC SIMIT Simulation Platform - Overview As with pcs 7, here you will find FAQs, manuals, application examples including example projects, movies and training. |
SIMATIC PCS 7 - Overview |
