3/1/2022 10:45 AM | |
Joined: 4/16/2021 Last visit: 8/1/2023 Posts: 16 Rating:
Hello Thank you for your reply. We are using Mindconnect Lib asset and it is programmed by node red. |
3/1/2022 1:15 PM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, without knowing details about the MindConnect stuff, I would say that after the key expired you can refer to the documentation of the MindConnect node (e.g. the part "Troubleshooting"). I would guess that either the node (having an error) or your asset share the information that a kex is expired. To check the information from the node, the only way is to implement some logic for that. I attached an example flow for buffering. I received that from a colleague without testing it. Best regards! AttachmentMCBuffer.zip (811 Downloads) |
