3/30/2021 4:29 PM | |
Joined: 4/28/2015 Last visit: 9/9/2024 Posts: 3345 Rating: (379)
Hi, strange, usually the IP address of your router should be in there. Are you using dhcp? There is a workaround (see second post) for this, usually this only needs to be done using a static IP address. Best regards! |
4/5/2021 10:26 AM | |
Joined: 2/20/2015 Last visit: 8/5/2022 Posts: 14 Rating: (0) |
HI, I have allready solved problem with internet access. I'am able to start installation now. During installation following warnings appears and it's impossible to use node on web frontend. Attached you will find screenshot aof node-red catalog. It someone hwo now this problem? [snip] Attachmentfiles.zip (857 Downloads) |
Last edited by: AutoGen_236829 at: 04/05/2021 10:28:31Last edited by: Jen_Moderator at: 04/06/2021 13:23:58New subject after splitting Last edited by: Jen_Moderator at: 04/06/2021 13:26:44Added error-message as txt file. Last edited by: Jen_Moderator at: 04/06/2021 13:29:55Removed splitting-remark. D.Wetzel |
9/10/2022 7:30 PM | |
Joined: 7/25/2017 Last visit: 9/19/2024 Posts: 317 Rating: (47) |
Hello Der_D, did you find a solution to this problem? |
