11/7/2022 10:53 AM | |
Posts: 2 Rating:
Hi Oskar I had a similar problem using WinCC Unified Toolbox example project. https://support.industry.siemens.com/cs/ww/en/view/109770480 Navigation.HighlightButton is a custom JScript of that project, not a proper System function of WinCC Unified (as ChangeScreen, for example). You can find it in Script>Navigation folder. If you check it, you will notice that the current JS code will not work for changing BackColor for items in another window screen different from the one that called it. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/08/2022 06:23:28Link optimized. Last edited by: Jen_Moderator at: 11/08/2022 06:28:46New subject after splitting |
