9/13/2024 9:31 AM | |
Joined: 5/6/2022 Last visit: 10/11/2024 Posts: 464 Rating: (92) |
Hi tilha, I have seen the error "en-US; Cannot set the editing language" before and on two occasions it was solved by reinstalling the TIA Portal software. Therefore, from what I know, I think you will have to start the installation from scratch or at least try to repair it because it seems that something has not been installed correctly. Best regards!
9/13/2024 10:40 AM | |
Joined: 8/3/2009 Last visit: 10/11/2024 Posts: 13911 Rating: (1757)
Hello tilha It is worth a try to delete the temporary files: https://support.industry.siemens.com/cs/de/en/view/109778709 Bye Murof |
9/17/2024 1:37 PM | |
Joined: 2/20/2014 Last visit: 9/24/2024 Posts: 14 Rating: (0) |
Thank you very much for your help, I just tried to uninstall Tia Portal V16 and reinstall it but it didn't work. I decided to format the PC and reinstall Tia Portal V16, everything started working again Thank you for your help
9/17/2024 1:40 PM | |
Thank you very much for your help, I tried this procedure but it didn't work I uninstalled Tia Portal V16 and reinstalled it and it didn't work either. I formatted the PC and reinstalled Tia Portal V16, everything started working again Thank you for your help
