9/13/2021 2:53 PM | |
Joined: 3/21/2019 Last visit: 8/19/2024 Posts: 2 Rating:
you need to download TIA portal support package, it can be found on below link for TIA V14: https://support.industry.siemens.com/cs/cn/en/view/72341852 |
9/11/2024 7:05 AM | |
Joined: 2/9/2015 Last visit: 9/11/2024 Posts: 9 Rating:
I've had the same problem. If you have WinCC installed make sure that the HMI panel you want to open is supported by WinCC version you have. Check this threat: https://support.industry.siemens.com/forum/pl/en/posts/different-between-wincc-versions/133082/ If you happend to have WinCC Basic but your panel needs WinCC Comfort or Advanced then this threat may save you lots of time: |
