(0)| 1/16/2020 9:39 PM | |
Posts: 1 Rating:
Hello When i turn on the IPC427D only the yellow led flashes and nothing else happens on the screen. How could you help me out? |
| 1/20/2020 12:38 PM | |
Joined: 10/18/2012 Last visit: 1/22/2026 Posts: 225 Rating:
Hello Messbb, LEDs indicate the status of the device. See PDF page 19 of the IPC427D operating manual at https://support.industry.siemens.com/cs/ww/en/view/67235073. The only yellow flashing LED is the PC ON/WD LED and it is supposed to flash green/yellow. If you saw this behavior then your IPC is in POST (power on self test). The IPC checks it's components. This typically doesn't last longer than a couple of seconds. Maybe you should consider asking the support for further assistance. The Siemens Technical Support page is here: regards, |
