(38)| 8/21/2018 11:33 PM | |
Posts: 1 Rating:
Company Name? WORKERBASE Company Type (OEM, System integrator, End customer with manufacturing environment)? System integrator What is the role of the IOT2040 in your project? Collect data from PLC and send to cloud, display data on smartwatch for industry Use case: mobile alarm management Why did you chose the IOT2040 for your project? Easy to use iot gateway with nodered How did you find out about the IOT2000? internet research |
| 8/6/2019 8:25 PM | |
Posts: 2 Rating:
Hello, how were you able to read PAC2200 Double type data? |
| 8/19/2019 9:29 PM | |
Posts: 7 Rating:
And here is mine (IOT2020): What is the role of the IOT2020 in your project? The IOT2020 plays the central role: Data logging, storing and visualization Why did you chose the IOT2020 for your project? I made a extensice comparison between the avialable devices on the market - How did you find out about the IOT2020? PC/Hardware related news portal. Here you can find an advanced description on Medium (also with some pictures). |
| 1/24/2020 7:22 AM | |
Posts: 33 Rating:
THE LINK YOU PROVIDED DOESN'T WORK |
| 7/10/2020 6:52 PM | |
Joined: 12/15/2019 Last visit: 10/23/2025 Posts: 20 Rating:
Hi , Company Name? Lumit.io Company Type (OEM, System integrator, End customer with manufacturing environment)? System Integrator What is the role of the IOT2040 in your project? Edge Computing Device We are using the IOT2040 and now the new IOT2050 with our edge computing framework " Legacy Connector " . [snip] |
Last edited by: Jen_Moderator at: 07/13/2020 07:08:32Removed link, because it's an advertisement. |
