4/29/2022 7:23 AM | |
Joined: 8/20/2021 Last visit: 2/9/2023 Posts: 19 Rating: (0) |
Hi bergmanu, I attached the node-red flow. There is none a special tag/DB, you can see in my flow, every time accessing variables are getting the same DB address. best regard!
Attachment3RT S0-2.txt (907 Downloads) |
5/16/2022 4:12 AM | |
Hi bergmanu, I have a new try, I copy the flow from IOT2040 to my PC and deploy on PC, then I monitor them at the same time, the error only occurs in IOT. I attached a video which shows the error moment, in the video left half part is about IOT, the right is flow deployed on my PC. You can see when the error occurs in IOT, at the same time PC flow is normally. Could you give me additional suggestion? Thanks in advance!
AttachmentS7 in node failure.avi (829 Downloads) |
