(0)| 10/31/2024 12:40 PM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi In this case, the first thing I would recommend you to share with us is the error logic to see what error you get in the block and to check what may be happening: "How do you evaluate the status of system blocks in STEP 7 (TIA Portal)?" Can you send us the code you get? On the other hand, I am going to send you some links that may help you: We are waiting for your answer, Best regards!
| 11/4/2024 9:52 AM | |
Joined: 10/31/2024 Last visit: 12/6/2024 Posts: 3 Rating:
Good morning, |
