9/25/2018 4:25 PM | |
Joined: 11/15/2015 Last visit: 8/1/2025 Posts: 180 Rating:
Hello ChristophD, thanks a lot for your helping, Now, i have an old project created with wincc flexible 2008 SP3, i saved it as version SP2 according to the messages that were appeared in order to migrate it to v11 to download it to the panel TP700 Comfort. I downloaded TIA v11 as you told me and i installed it without any problem. now i attached the error. please help me what i shall to do??? Many thanks ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 9/30/2018 9:49:39 PMNew subject after splitting Last edited by: CS Moderator at: 9/30/2018 11:13:04 PMLook for alternative not for the correct answer...if this is helping you rate it. |
2/16/2022 2:50 PM | |
Joined: 2/24/2012 Last visit: 2/13/2024 Posts: 28 Rating:
You have solved this problem ? I have identical problem and have a identical ERROR. Please help to solve this problem. |
2/24/2022 2:41 PM | |
Joined: 8/3/2009 Last visit: 9/11/2025 Posts: 16400 Rating:
Hello I think there are different Controls. Look at this FAQ: https://support.industry.siemens.com/cs/de/en/view/109477029 Bye Murof |
