12/21/2023 1:33 PM | |
Joined: 8/3/2009 Last visit: 10/18/2024 Posts: 13982 Rating: (1760)
Hello AutoGen_4776519 could you send us a screenshot where we can see where the Screenshot is taken from... I think the column is the "Symbol"-> if you have an integrated WinCC lfexible Project in Siamtic Manager and you use an integrated connection youcan browse in the DBs and select the tags. then a PLC Symbol is set to the tag perhaps this one could help: https://support.industry.siemens.com/cs/ww/en/view/80919613 https://support.industry.siemens.com/cs/ww/en/view/19323562 Bye Murof |
Last edited by: Murof at: 12/21/2023 13:36:58If this Information really helps, you could use the Rate function |
12/22/2023 7:06 AM | |
Joined: 8/31/2023 Last visit: 2/15/2024 Posts: 8 Rating: (0) |
Hi Murof, i got a new screenshot. |
1/23/2024 9:36 AM | |
Hello AutoGen_4776519 Which Version of Step7 and WinCC flexible do you have exactly (With SP and Upd or Hotfix) If you cannot get access to the PLC DBs in the Tag selection dialog then do you have checked this FAQ that I mentiioned: https://support.industry.siemens.com/cs/ww/en/view/80919613 Bye Murof |
Last edited by: Murof at: 01/23/2024 09:36:49If this Information really helps, you could use the Rate function |
