7/4/2024 8:35 AM | |
Joined: 8/3/2009 Last visit: 7/18/2024 Posts: 13310 Rating: (1686)
Hello ENGİNCAN The TP900 Can act as OPC UA Server and on WinCC Prof RT you can go with the OPC UA Channel (client). In this FAQ there are a few examples how to work with it, I´m not sure if there is exactly your situation but you should find all important information: https://support.industry.siemens.com/cs/de/en/view/63481236 Bye Murof |
