8/12/2020 10:04 PM | |
Joined: 9/27/2006 Last visit: 9/15/2025 Posts: 12408 Rating:
Hello CodyBanks; The Sitrain website contains a good description of every course they can offer you, including this one: S7 Programming 2 Course (ST-PRO2) https://www.sitrain-learning.siemens.com/UK/en/rw47494/S7-Programming-2-Course Content Using structograms as a method for program design Functions, function blocks and multi-instances ((with examples using IEC Timer/Counter) Jump commands and Accumulator operations Configuration of Breakpoints as a debugging tool Memory Indirect addressing Integration of a drive (MM420) using PROFIBUS DP Monitoring and controlling the drive with the "Starter" software Using Error organization blocks to evaluate Profibus slave downtime Error management with error organisation blocks Analysing synchronous errors with organisation blocks Analysing S7 diagnostic data Writing user messages in the Diagnostic Buffer Troubleshooting and error messages with an HMI Touch Panel Each of the above topic areas are backed up by practical exercises using a system model, consisting of the S7- 300 automation system, the ET200S distributed peripheral, an HMI touch panel, the MM420 drive and a conveyor model. Working examples are provided and tested out during the course. Siemens has also prepared tutorials for self-learning (free downloadable) that parallel the official Sitrain courses; they are grouped as SCE Learning and Training Documents. You could use the different modules offered in their website to help you with your training during the pandemic. Hope this helps, Daniel Chartier |
8/12/2020 11:09 PM | |
Joined: 8/24/2018 Last visit: 2/10/2025 Posts: 23 Rating:
Thank You. It helped a lot. |
Automation is about making things talk |
8/13/2020 9:44 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
Hi CodyBanks92, Have you heard about SITRAIN – Digital Industry Academy?
Best regards, |
2 thankful Users |
8/14/2020 2:19 AM | |
Thank you for the information |
