6/21/2014 11:40 AM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello, Number 70011: If the first parameter in the system alarm is displayed with the value 13, the second parameter indicates the byte containing the incorrect value. Havea look: WinCC Flexible 2008 I don't know which panel you have but perhaps might help you, go to Page 267 http://support.automation.siemens.com/WW/view/en/23337820 |
8/31/2023 2:44 PM | |
Joined: 6/18/2020 Last visit: 7/2/2025 Posts: 12 Rating:
Dear, I have the same issue in TP900 comfort, the link which you mentioned is not working. Can you please post another link or any documentation for help. Thanks in advance. |
2/25/2025 12:48 PM | |
Joined: 8/3/2009 Last visit: 9/17/2025 Posts: 16447 Rating:
Hello Quentin use the latest Version of WinCC flexible 2008 SP5 (Upd2)-> and check the rights in OS: https://support.industry.siemens.com/cs/ww/en/view/59203176 do also check the compatibility from your OS to the used WinCC flexible Version: https://support.industry.siemens.com/cs/de/en/view/64847781 Bye Murof |
