2/26/2018 7:35 AM | |
Posts: 1 Rating: (0) |
Hello, KTP400 comfort HMI device not conneting ethernet, we checked below Open Simatic ProSave. Choose in the Register "General" your Panel. Change in the Register "OS Update" Set the Setting "Reset to factory settings" Type your mac addresse in. Click "on Update OS" We are getting connection error Then we are trying to connet Primary setup tool , i cant find my device. 1. Start-> Control Patel -> Set PG/PC Interfaces S7ONLINE! and choose ISO Ind. Ethernet->"my eth card name" 2. HMI - power ON , start TIA portal ORPrimary Setup Tool,in menu Online-> Accessible device, wait to find your HMI ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/26/2018 8:01:12 AMNew subject after splitting |
3/14/2018 8:38 AM | |
Joined: 4/24/2006 Last visit: 8/8/2024 Posts: 8713 Rating: (1166)
Hello, Perhaps you can try to reset to factory settings using USB stick: USB Recovery (Reset to factory) Mode for 2nd Generation Basic Panels Best regards, Wizard |
1/13/2019 1:42 AM | |
Posts: 8 Rating: (0) |
You rock! I had a KTP400 that was a brick and with your help I was able to bring it back to life. Thanks so much! |
4/24/2019 7:01 AM | |
Posts: 10 Rating: (0) |
Hi Wizard Thank you for this . I have used it and it works . [snip] Regards lang piet |
Last edited by: Jen_Moderator at: 04/24/2019 13:39:35Division of questions into seperate topics. |
