1/19/2024 8:51 PM | |
Joined: 1/19/2024 Last visit: 1/19/2024 Posts: 1 Rating: (0) |
Hi I have this problem too Although I have done all the registration steps carefully and received the registration confirmation email, I still do not have access to any of the downloaded files. Please, if possible, send the Modbus RTU V20 Drive in TIA V 15 program and documentation until the problem of my account in downloading files is solved. Thank you Best Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/22/2024 09:58:07Text formatting optimized. E-Mail address removed, doesn't comply with forum terms. Last edited by: Jen_Moderator at: 01/22/2024 09:59:11New subject after splitting |
1/19/2024 9:19 PM | |
Joined: 1/21/2013 Last visit: 9/27/2024 Posts: 3140 Rating: (489) |
Hi Farab Tajhiz, I am not sure how you are trying to access this sample application. However, you can find the correct link in the application example entry. Try downloading it from that link. However, for some reasons you may not be able to access the downloads. This could be due to an embargo, for example. If this is the case, no forum member is allowed to send you the example. By the way, for privacy reasons, you should edit your post to remove your email address. Kind regards |
1/22/2024 11:55 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (172) |
Hello Farab Tajhiz, I have inquired internally about the status of your approval and received the information that the check has not yet been completed. Please wait until you have received an official e-mail from Siemens. Regards, |
3/6/2024 2:02 AM | |
Joined: 2/25/2022 Last visit: 9/9/2024 Posts: 2 Rating: (0) |
I go through the same situation. I can't download any .exe or .zip files Just the .pdfs What should I do? |
