4/7/2024 4:56 PM | |
Joined: 1/5/2021 Last visit: 9/18/2025 Posts: 1 Rating:
Hi experts! The DMC open library has been around for many years and I've used parts of it for several projects. Siemens Open Library (openplclibrary.com) It has function blocks and faceplates for Siwarex WP321 ST. Their function block uses the fbSiwarexWP321Limited_SIMATIC (FB321) in multi-instance. Info says its version V4.1. Is this compatible with 7MH4138-6AA00-0BA0 and CPU 15010SP-1 PN V3.0? I'm asking because there are several versions relating to firmware and CPU version in the Siemens official Siwarex library. |
4/8/2024 9:29 AM | |
Joined: 1/4/2007 Last visit: 8/26/2025 Posts: 1190 Rating:
Hello B-9020, Well, the function-block version V4.1 is quite old. The current function block version is V4.8. I recommend to you to use the current function block. This function block is running with S7-1500 PLCs, firmware higher than V2.0. You can find the current function block here: https://support.industry.siemens.com/cs/ww/en/view/94109373 Best regards Siwarexi |
