5/30/2024 6:33 AM | |
Joined: 6/23/2013 Last visit: 8/1/2024 Posts: 62 Rating: (6) |
The dpConnect is basic knowledge, that every WinCC OA engineer should be able to use it after having the basic training. Probably 99% of the projects depend on the dpConnect functionality, so pretty sure it works. What did not work? What code did you produce, that is not working? Did you try any of the examples in the documentation? Did you follow a WinCC OA training? Or went thru the tutorial? Did you check how the wizard creates the dpConnect for your case? |
Last edited by: Jen_Moderator at: 05/31/2024 10:04:17Text formatting optimized. WinCC OA expert |
