10/11/2024 4:41 AM | |
Posts: 3 Rating:
Hi I have a monitoring pac3200, 3 phase voltage sample have connected to the device without pt. when it shows the votlage , there is difference between 3 phase to phase voltages, for example , the voltages are 400 volt and it shows for each phases 400, 380, 390 . how can I fix that problem, could it be fix by reset factory or updating the frimware? thanks. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 10/11/2024 05:49:33New subject after splitting |
10/11/2024 5:50 AM | |
Joined: 7/30/2024 Last visit: 9/16/2025 Posts: 960 Rating:
Closed because posted twice. The active topic can be found here: centron pac 3200 voltage showing error
Kind regards, Moderator_Lan |
