3/19/2025 8:04 AM | |
Joined: 10/16/2024 Last visit: 9/16/2025 Posts: 1 Rating:
Hello, did you solve the problem? I am stuck at same point. |
7/2/2025 7:41 AM | |
Joined: 3/21/2013 Last visit: 8/7/2025 Posts: 24 Rating:
Hello, I have some updates on this issue. Please check if on the PC(which you want to attach to the UMC Server) if the service “UMC Secure Communication" is running. I attached a document which could be helpful to check some additional points. Currently I am blocked by an error in TIA Portal, which appears when I want to synchronize with UMC Server. I checked and changed the password of the UMC user which has Administrator role, but the error still appears. AttachmentAttach_UMC_Agent_config.pdf (203 Downloads) |
8/4/2025 4:18 AM | |
Joined: 7/20/2023 Last visit: 8/25/2025 Posts: 1 Rating:
Hi GabyT, Did you solve this error code 4? I have the same issue. |
