1/3/2011 4:35 PM | |
Posts: 206 Rating: (22) |
Dear monier, please excuse the late answer. If you have the exact same setting on a secondSiwarex U running correct there might be a problem with the first module. Does the first module give a message? What did you see as reading? Whatis different to the second module? Is it possible to read all data from the running second module and try the first module again with this data? And if you are online you can read all data and post it here or send to siwarex.hotline.aud@siemens.com. Regards |
